Hi there, I'm using for a client Photoproof child theme and inside each work sections (work media/add images), the possibility to upload media and select them disappeared. Even in works created previously, media have disappeared. I have a notification for updating
WPBakery Page Builder to version 5.5.5 but being purchased this with the theme I can't update that. Maybe is the reason. See attached screenshots. Thanks so much for your answer.
Gabriele
Have you updated the Apollo13 Framework Extensions plugin? It should fix this issue.
https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-bundle-plugins/
