Akito said:these are my installed plug-ini already try Elementor 2.30 & 2.31 the same issue
1. What version of Apollo13 Framework Extensions do you have installed?
2. What other plugins do you have active on your website? (You can make me a screenshot of your plugins page).
That sometimes happens. We just need to find out with which plugin, and later find out how to fix it.
