Like you can see the team of Elementor removed support for fixed background on the mobile, you know why? Because it was broken! Right now you cannot predict how it will work on all mobile devices. On some, it works fine and on other, it's not. I hope the will find another way to display parallax pictures but for now, I suggest you, don't enable fixed on mobiles.
There is no CSS that would allow I could add then eh Daniel? Where is the option to enable fixed on mobile? Elementor settings? Yeah really hope Elementor makes Parallax and Fixed mobile style options priority, it's ALL about Mobile Style 2018 forward! The Jet Elements plugin for Elementor has butter smooth multi layered parallax https://elementorpagebuilder.demo.site/ Here's a super smooth fixed background that works on mobile by the way https://thewebstyliststudio.demo.site/under-construction-coming-soon-page/
I believe Elementor didn't yet come to parallax parts, and they only have the option to enable background-attachment: fixed which is very buggy on mobile, especially when you want to create 100% height sections.
That is why they switch it off on mobiles. I don't know if they will add JavaScript controlled Parallaxes like WPBakery does, but they should in my opinion.
If you have found a plugin that makes it work for Elementor(like that "Jet Elements"), then, for now, I would stick to it on your place :-)
Heyyyy Sir Air! Ahhhhggg too bad about no fixed backgrounds, yeah some themes have it butter smooth, like this site I'm redesigning https://recklessinvegas.demo.site/ I hope that becomes an option sooner than later.
Curious, how does your Rife Elementor plugin work? I checked out on your forum but don't see those template import options here I don't need for this NEW RIFE SITE! https://marikaberoukas.com/ but was just curious as I didn't notice that plugin til now BIG UP$!!
About parallax - in the theme, we have only parallax in title-bars and it should be much smoother. As for content parallaxes, that I know that you love, they always come from page builders.
And I was curious where does the title parallax area pull the background image from? I was just playing with this demo from a while ago and couldn't find where that option is. https://rifetheme.demo.site/about-i/
Also I thought I'd check in to see if any upgrades/improvements in the last year w Rife I might not know about?!
TheWebStylist said: And I was curious where does the title parallax area pull the background image from? I was just playing with this demo from a while ago and couldn't find where that option is.
TheWebStylist said: Also I thought I'd check in to see if any upgrades/improvements in the last year w Rife I might not know about?!
There wasn't any big news this year. Mostly we spend time making sure that everything works with all those Elementor and WordPress updates that happened this year.
Best Regards
Big Thanks for all your awesomeness #RIFEROCKS
which is very buggy on mobile, especially when you want to create 100% height sections.That is why they switch it off on mobiles. I don't know if they will add JavaScript controlled Parallaxes like WPBakery does, but they should in my opinion.
Sorry that I don't have better news.
I love your positivity!
BIG UP$!!
Hope 2019 Good and 2020 headed towards AMAZING!$
BIG UPS! all ways forward
Time flies so fast. Nice to hear from you :-)
This image is set as the background of the section in the Elementor. Here is the instruction how to change it https://apollo13themes.com/basic-elementor-plugin-tricks/#parallax
