Hi Guys
Im trying to change my site fonts to match Gruby via customizer.
Looking at customizer the only settings I can find are for Headings and then 1 for site content
But when I look via whatfont at Gruby its using Poppins and Segeo UI
Segoe UE is not a system font - how do you add it
How do I get the same site wide font settings? I have ended up with multiple fonts and sizes even though Elementor settings for fonts are disabled
I cant find enough info in the docs to work out where to change fonts sitewide to include line height, spacing, colours etc. I dont want to change every section in Elementor
Dev site details sent by email - thanks
Like you can see here: http://nimb.ws/egCsoA . Site content font is set to Native Font that means that your operation system will decide which font display on your page.
You can change it to something else from the google fonts eg. Poppins.
If you have the Windows it will display the "Segeo UI", check the code in the CSS styles: In few minutes I'll answer on the second part
If you wish to change the fonts spacing, you can do it in the Fonts Settings: https://rifetheme.com/help/docs/customizing-the-theme/general-settings/fonts-settings/
Please provide more details and we will find it quickly
Best Regards
