How can i add my Album (present media in scroller parallax) on my page (page with text and other elements)? It must be album, not "Theme Scroller" because the album has more options like "Space between cells".
I see now, that this one single option for scroller that requires CSS block, doesn't go to Elementor. I will fix it for next update, meanwhile, do this to fix it please use this custom CSS:
Use the Theme Scroller :-D
You see, theme scroller widget takes options, that are not available in Elementor widget, right from Album that uses as the source.
So for example "Space between cells" will be inherited from album, as it is currently not available as the option in widget :-)
Let me know if you face any issues.
page:
http://kotniz.eu/2019/technologia
album:
http://kotniz.eu/2019/album/okucia
I see now, that this one single option for scroller that requires CSS block, doesn't go to Elementor. I will fix it for next update, meanwhile, do this to fix it please use this custom CSS: Thanks for reporting this!
