escaping menu
in Rife Posts: 42
On the iPad, when scrolling down the menu moves up.
    Could you send me a live link to your website so I could see what could be going on?
    It seems your website is hidden under 3 dots :-)
    Can't view it.
  • edited December 2018 Posts: 42
    website is visible :-)
    Post edited by farell on
    I have been on your website and tried to bring this issue, but it worked fine for me.
    Does it happen every time or depending on the situation?
    I check if there is any possibility for measurement errors on smaller resolutions.
    It happen every time - ipad pro 12,9" 1G
    So it is larger iPad that I don't have access to.
    Does it fix if your turn screen vertical and back to horizontal?
    When I turn screen vertical (the mobile menu appears - three lines) and back to horizontal - the menu is invisible for a moment and later is on the top.
    Hey there:-)
    I tried hard and I can not recreate this consistently.
    However, I see that occasionally on window resize menu position is messed up. I think this is connected to what you have reported.
    I will investigate resizing of the vertical header for the next update. So it should be better with version 2.3.0.
