Discussions
Categories
Home
Rife
escaping menu
farell
December 2018
in
Rife
On the iPad, when scrolling down the menu moves up.
Air
December 2018
Could you send me a live link to your website so I could see what could be going on?
farell
December 2018
http://kotniz.eu/2019
Air
December 2018
It seems your website is hidden under 3 dots :-)
Can't view it.
farell
December 2018
edited December 2018
website is visible :-)
Post edited by farell on
December 2018
Air
December 2018
I have been on your website and tried to bring this issue, but it worked fine for me.
Does it happen every time or depending on the situation?
I check if there is any possibility for measurement errors on smaller resolutions.
farell
December 2018
It happen every time - ipad pro 12,9" 1G
Air
December 2018
So it is larger iPad that I don't have access to.
Does it fix if your turn screen vertical and back to horizontal?
farell
December 2018
When I turn screen vertical (the mobile menu appears - three lines) and back to horizontal - the menu is invisible for a moment and later is on the top.
Air
December 2018
Hey there:-)
I tried hard and I can not recreate this consistently.
However, I see that occasionally on window resize menu position is messed up. I think this is connected to what you have reported.
I will investigate resizing of the vertical header for the next update. So it should be better with version 2.3.0.
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
590
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
December 2018
farell
December 2018
Air
Discussions
Categories
Sign In
Can't view it.
