Hi
Please can you help
I cant see how to set the nav menu item active colour to be different from the hover link
e.g, I want orange as the link colour but a different colour as the active menu item font colour -
See dev site - active and the link colour are both orange - and I need to change the active hover menu item font colour to not be orange
You have set it good - it is orange on hover and active.
However, none of your links in the main menu is the current page :-)
As I am using an orange background you cant see the active nav menu item - I need to change the font color to be different from the active link
See Screenshot - both are orange - how do i change the nav menu item font colour on active only to be different from the underline link - see the login menu item
In theme, one color is used for both states. We didn't want to multiply options even more, as it already too many of them:-)
For your current menu structure this should work: Please use this custom CSS: With kind regards.
