hey! i decided to change my landing page from albums to my offer and it seems to indclude albums as well when i scroll down. i want my landing page to contain only my offer. is this a bug or do i just do something wrong?
my adress:
http://zakrzewski.photographywordpress 4.9.9
It seems your support died 3 days ago. I will reply anyway, but please think about renewing: https://rifetheme.com/apollo13-framework/docs/getting-started/support-forum/expired-support/
It seems you have set up your Albums list as the front page.
You can either, move your new content to a new page and set this new page as the front page.
Or you can disable "Albums list" template on your current front page https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/adding-albums-list/
As for renewing it is almost certain that I will just buy more licences (already have 3) as I will need one for my bands page
Anyway, to make things clear - I have my Oferta page set up as front page - and it is set to default template, not albums. I had Albumy set as a front page before and changed it recently. Now it displays BOTH Oferta AND Albumy, one after another, though according to the settings I have and your suggestion it should only display Oferta.
-send me created login and password Wow, that is great!
In theme settings for the front page, you have to change from Albums list to Page. https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/general-settings/front-page/
It will solve it :-)
