I installed Caroline Rifle design a long time ago. From the very beginning I could not enter the Elementor edition in the "Home" page, the "Preview Could Not Be Loaded" error appeared. Interestingly, all the other sites from the imported Caroline were working fine and I could edit them. I built practically the whole page with Elementor and the time has come that I need to edit the Home page.
Can I give you a login and password to my website so that you see how it is?
How much memory do you have on your server? Maybe you are reaching the limit?
See WP Memory limit https://rifetheme.com/help/docs/getting-started/checking-server-requirements/
Could you please send me temporary access to your WordPress so I could check there what is going on? Send it here on the forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
Your front-page is set as an album. Albums are very simple and mostly gallery oriented, with by default disabled area for content(this is why Elementor is failing probably).
You can enable it from theme options, but I would advise a different approach.
Create a new page for your front-page, edit it with elementor. You can use theme widgets to add a list of albums where ever you want later: https://rifetheme.com/help/docs/content-management/elementor-widgets/
Remember to set your new page as a front page as explained here https://rifetheme.com/help/docs/basic-setup/front-page/
