Hi
A cheeky question as its not the theme - I cant get an area of a section to be grey (bgd) instead of the white. I have tried everything I can think of - from recreating the section - etc etc.
Just wondered if you can see why this section is white in the background when it should be grey as per the section setting.
Dont worry if no time.
Page is metta3.vip/social-media-content/
See Screenshot for section issue - see the white rectangle part behind the social infoboxes!
Its probably an elementor thing! but I cant find it..
Thanks a lot
Actually, it is theme background showing up there :-)
Due to the negative margin on the section, it moved up, and there is nothing that could cover that area with color.
So instead of doing that on the section, do it on each column:
I have done it on your beta page.
