MyMetta said: I want white on display and a custom colour for hover so not sure why i would set white for hover??
Could you just do it? :-)
"white" in this situation is a parameter that sets class white_hover that I have given you CSS for. Your CSS will start to work once you will follow instructions to the end.
Unfortunately, all colors are predefined in CSS.
If you don't like our colors when you set "color" option for hover, I can help you with custom CSS.
For that, set "white" value for hover param and add this custom CSS: With kind regards.
I guess it has to go somewhere in Elementor? Im using an elementor widget in Footer Column 1
thanks
This is my CSS - set in customizer and style file but I am using an elementor section template that has a shortcode plus the image box..thanks
.socials.icons-only.white_hover a:hover{
color: #ee990e
white_hover
that I have given you CSS for. Your CSS will start to work once you will follow instructions to the end.With kind regards.
