It works when the site is an album, but now my album must be in the section on the page and this section makes unnecessary margins. Content side padding is "Both off".
I have edited our plugin on your site, and now it respects value set in the album. I will think about adding this setting to the widget in the next version.
Word of warning: you have now set over 5000px of max width and images will be scaled to such width and it will hurt your site performance.
A much better idea would be to keep it at 1920px, and set black or red (like your header) background color, that would be visible only on large screens like yours.
Remember that majority of users have screens in mostly full HD(1920px wide).
I'm aware that most people have 1920, but one person who will accept the site has Imac Retina 5k :-( Thank you for the modification will definitely work as always.
Content side padding is "Both off" but the page on 5k is not full width. The problem exists, for example, with this subpage: http://kotniz.eu/2019/drzwi-2/
As for first screen shot please check your other topic https://support.apollo13.eu/discussion/comment/23243/#Comment_23243
As for the second screen: please check page options https://rifetheme.com/help/docs/content-management/pages/pages-options/ and option Content side padding.
Thank you for the modification will definitely work as always. Content side padding is "Both off" but the page on 5k is not full width.
Please forget about my last answer. I did not see the small screenshot
Be back in a few minutes with an answer
With regards
The same story in other sections, edit paddings and margins to get desire results.
I hope it helps
With regards
But on iMac retina 5k i still have empty space like attach:
With regards
I want to make sure that your editions that you have made on my site will be still working.
Changes were made in the plugin, so yes - you can update theme :-)
