Hi
I have read all your theme header docs but seems I am missing something.
How do I get the nav menu to be visible at all times with black font. I have tried everything in customizer and turned off variants but still I cant see the nav menu on tablet landscape mode - theres no text there.
Also have an issue with Sticky Menu - logo is uploaded and does not show and font does not show either
Its possible that I have some wrong settings but its quite confusing
I will email you a login for the dev site
Do you mean the icon opening the main menu? For me it is currently white on white so invisible.
Go to Appearance → Customize → Header Settings → Tools icons to set the color of this icon.
Do you mean sticky header?
I have checked that you have uploaded same logo for normal and sticky header, so there will be no difference. However, to use you will need to go to Appearance → Customize → Header Settings → Type, variant, background and in → Header color variants choose Enable only for sticky variant.
If you mean something else, please explain in more details.
Thanks. No I dont mean the icon.
I think I have got confused with all the options.
This is what I am trying to do
Main Nav Menu Bgd Color is orange
On Scroll Down -I want to have a different coloured background e.g. white for the sticky header
Im sure the theme does this I just cant quite understand which settings to use - see kinsta.com for an example - just start scrolling down and you see the main menu change from dark colour to light - this is exactly what I wish to do if you can help.
I have the orange only colour working now but cant get the sticky header bit to work.
thanks
So you have to have active header color variants. Go to Appearance → Customize → Header Settings → Type, variant, background and in → Header color variants choose Enable only for sticky variant.
Next in Header settings → Sticky header - overwrites set all you colors for sticky header :-)
Simply you are overwriting here colors from normal variant. So if you will not set some color, default will be used.
Thanks. I tried this and set this to green colour just for testing
It doesnt show any green - just the same header background colour - orange
What am I missing?!
Im trying to create the header effect you seen on kinsta.com as you scroll down it changes from dark to light.
Appearance → Customize → Header Settings → Type, variant, background → Sticky version - chose one that is not "Disabled".
I didn't notice this previously, sorry.
The sticky header is showing with logo white bgd to header but no fonts showing on mobile devices in landscape or mobile - where do you set the sticky header font colour or is it being cut off???
Also what does it do on mobile?? Looks like it still shows I see a white sticky but no text or hamburger once I leave desktop
See screenshot for settings or see on live and dev site
See shot of what I see on tablet - or just reduce browser size - just white header and logo
Please read the whole answer that I have linked, because I told you this before, that you have not visible hamburger, and it is in that reply: So there you can set the color for icons in the header. In sticky header settings(Header Settings → Sticky header – overwrites), you can override it with option Tools icons - color.
Hope now you will be able to do it:-)
