white marign - not full width
in Rife Posts: 42
On the mobile and pc retina 5k site have white marign around the section elementor, not full width. Screen one the Attachment.
    As for first screen shot please check your other topic https://support.apollo13.eu/discussion/comment/23243/#Comment_23243
    As for the second screen: please check page options https://rifetheme.com/help/docs/content-management/pages/pages-options/ and option Content side padding.
    It works when the site is an album, but now my album must be in the section on the page and this section makes unnecessary margins.
    Content side padding is "Both off".
    I have edited our plugin on your site, and now it respects value set in the album.
    I will think about adding this setting to the widget in the next version.
    Word of warning: you have now set over 5000px of max width and images will be scaled to such width and it will hurt your site performance.
    A much better idea would be to keep it at 1920px, and set black or red (like your header) background color, that would be visible only on large screens like yours.
    Remember that majority of users have screens in mostly full HD(1920px wide).
    I'm aware that most people have 1920, but one person who will accept the site has Imac Retina 5k :-(
    Thank you for the modification will definitely work as always.
    Content side padding is "Both off" but the page on 5k is not full width.
    The problem exists, for example, with this subpage:
    http://kotniz.eu/2019/drzwi-2/
  • edited January 2019 Posts: 422
    Hi
    Please forget about my last answer. I did not see the small screenshot ;)
    Be back in a few minutes with an answer :)
    With regards
    Post edited by Daniel on
    Lead Graphic Designer
    Please switch Elementor to a mobile version and remove these paddings (check the screenshot).
    The same story in other sections, edit paddings and margins to get desire results.
    I hope it helps :)
    With regards
    1920 x 948 - 203K
    On the mobile it work - thanks :-)
    But on iMac retina 5k i still have empty space like attach:
    1600 x 1097 - 276K
    I'm not sure if it connected to any settings, please try to add a bigger picture instead of this one. From what I see this picture has 1600px wide.
    With regards
    Ok, i try - thanks :-)
    Can i update theme Rife Pro 2.2.0 to 2.3.1?
    I want to make sure that your editions that you have made on my site will be still working.
    Changes were made in the plugin, so yes - you can update theme :-)
