Since I updated, I´m not able to find the field to edit "custom fields" in work pages (the left text that stay fixed on some work layout pages). Did it changed to someplace else?
Did it! But now, for some sure I get the out of memory error: Fatal error: Out of memory (allocated 110100480) (tried to allocate 1024 bytes) in /home/equip125/public_html/designdaexperiencia.com.br/wp-content/plugins/elementor-pro/modules/theme-builder/documents/footer.php on line 25
Is it so huge of an update? Tried to increase memory but it didn´t work. I´m currently at my hosts chat queue to fix it up.
To get back to my dashboard, I had to mannualy delete the apollo framework folder at my wordpress installation. After that, I deactivated and deleted 6 other plugins and it still doesn´t work
Now, I can´t even access or dedit my website properly (since I deleted the older version of apollo framework). Is it anyway I can download the older version to keep my website on until I can fix the php memory issue?
Just FYI, the php memory increase worked like a charm. Thank you.
Not only you have one of the greatest wordpress themes I've ever seen, but also the best and kindest support of all. I really appreciate this, Air. Thank you again.
Be sure to update the plugin Apollo13 Framework Extensions.
Increase memory to 256MB https://codex.wordpress.org/Editing_wp-config.php#Increasing_memory_allocated_to_PHP
https://apollo13themes.com/how-to-download-old-version-of-wordpress-plugin/
Plugin link https://wordpress.org/plugins/apollo13-framework-extensions/advanced/
I'll try to fix it out and come back with the updates later
Have a great day!
