Not able do edit work custom fields after update
Since I updated, I´m not able to find the field to edit "custom fields" in work pages (the left text that stay fixed on some work layout pages). Did it changed to someplace else?
Thank you.
[]'s
    Be sure to update the plugin Apollo13 Framework Extensions.
  • Did it!
    But now, for some sure I get the out of memory error:
    Fatal error: Out of memory (allocated 110100480) (tried to allocate 1024 bytes) in /home/equip125/public_html/designdaexperiencia.com.br/wp-content/plugins/elementor-pro/modules/theme-builder/documents/footer.php on line 25
    It seems you don't have enough memory for your current plugins number.
    Increase memory to 256MB https://codex.wordpress.org/Editing_wp-config.php#Increasing_memory_allocated_to_PHP
  • Is it so huge of an update?
    Tried to increase memory but it didn´t work. I´m currently at my hosts chat queue to fix it up.
    To get back to my dashboard, I had to mannualy delete the apollo framework folder at my wordpress installation. After that, I deactivated and deleted 6 other plugins and it still doesn´t work :open_mouth:
  • Now, I can´t even access or dedit my website properly (since I deleted the older version of apollo framework). Is it anyway I can download the older version to keep my website on until I can fix the php memory issue?
    guifollmann said: After that, I deactivated and deleted 6 other plugins and it still doesn´t work
    Hmm, maybe there is some other issue that make memory leak. Strange.
    guifollmann said: Is it so huge of an update?
    No, you probably were very close to the memory limit for a longer time.
    guifollmann said: Is it anyway I can download the older version to keep my website on until I can fix the php memory issue?
    https://apollo13themes.com/how-to-download-old-version-of-wordpress-plugin/
    Plugin link https://wordpress.org/plugins/apollo13-framework-extensions/advanced/
  • Thank you very much for your support.
    I'll try to fix it out and come back with the updates later
  • Just FYI, the php memory increase worked like a charm. Thank you.
    Not only you have one of the greatest wordpress themes I've ever seen, but also the best and kindest support of all. I really appreciate this, Air. Thank you again.
    Thanks for the update and the kind words!
    Have a great day!
