The menu in lowercase
How to change the menu to lowercase
Thank you
Toni
Ps: you are the best
    Hey Toni:-)
    Long time not seen here :-) Hope you are well.
    About changing the menu to lowercase. If you are using classic menu then go to
    Appearance → Customize → Header Settings → Main Menu.
    There you will find the option "Text transform" -> set it to None.
    Hope this helps.
    Hey,
    Thank you for your quick reply!!
    That's what it seemed to me, but it does not work.
    I learned how to use your theme work, but here I am stuck. (with set it to none)
    ps:That's why I bought a second license because you are the only ones to have an after sales service at the top and the only ones that have recurring updates !!
    Thank's
    Toni
    Please log in to the forum to reply next time ;-)
    Could you share a link to your website? I will check what could be going on.
  • edited February 2019 Posts: 18
    Post edited by tonimoltisanti on
    resolved
  • Hello,
    It's settled, it's my fault ..
    I was too fast, I changed the button at the bottom of the Header Settings → Main Menu.
    I did not see that in the middle there was another one!
    Thank you
    That is great to hear :-)
    Sorry that I couldn't help you during the weekend.
    Have a great week!
