Hi. I did the update to version 2.3.4 and received an email from google search console with 4 errors of the mobile version.
Could you say how to fix it or if it is a bug of the subject?
is that in all the time I've been there, they had not sent me this kind of message and it had not touched anything on the subject for months.
MESSAGE SEARCH CONSOLE:
Search Console has detected that there are 4 new Mobile Usability type problems on your website.
Most important problems (5 maximum)
The following problems have been detected on your website:
The content is wider than the screen
The clickable elements are too close to each other
The graphic window has not been defined
The text is too small to read
Thank you
We are receiving similar errors once every half year, however, when I go to the search console it is already reported as "fixed".
I believe it happens when styles(CSS) are not loaded in time.
You can check in your search console if you can find any more details about each issue. If not - ignore it.
