I have a landing page in several languages. I have successfully configured all of them except the Arabic version. Menu is not working at all. What should I do?
No, this is not the case. Look at the Chinese version of my website - https://digital.bahtiyar-world.com/zh/ Even though chars are not in English, it is working absolutely fine.
Please, resolve the problem without referring to the non-English thing. Thanks. I will be waiting!
It works, because you now have English chars IDs(as anchors in the menu and IDs in sections) , previously they were in Arabic chars. Maybe you have changed earlier, but they were cached.
Anyway if you want to have Arabic IDs instead use files that I am about to send you.
It is the same as in your other topic. Non-English chars as IDs seems to not be working well with scrolling.
I will test if I can make it work
I will reply here as soon as I get more info :-)
With
For example your Arabic ID
https://website.com/ar/#عني
is decoded as
https://website.com/ar/#%D8%B9%D9%86%D9%8A
That is why such ID cannot be found. I will check If I can reverse encoding in theme script. But your IDs are English chars in the Chinese version. So your point doesn't seem to be valid :-)
#team, #portfolio etc.
In a few minutes, I will send you privately link to download. The fix will also come in the next update.
You will have to download the file, unzip it, and upload contents to wp-content/themes/a13-onelander/js/
Thanks for your help.
BTW, Thanks for the file. Keep it for someone in the future. I will write you a great review right now!
