Hi
Hope your well. I have the footer scroll enabled but im seeing mixed results.
Its creating a sort of transparency when it scrolls on some pages which looks odd - is this the default bevaviour or should it just stay as a colour block - see
https://metta3.com/ - weird almost transparent orange
https://metta3.com/social-media-content/ - works perfectly
https://metta3.com/schedule/ - issue with footer
This happens when you have no solid background, then you can see footer bleeding through.
Please use solid background color on rows where you see the issue.
