Dear Apollo 13 Team,
I am using Rife Pro on WP and I am not interested in using Elementor Page Builder for various reasons.
I want to change the text color of one single menu item.
I want to achieve this:
https://organicweb.com.au/wordpress/how-to-change-the-style-of-an-individual-menu-item/I tried the above method to add custom css.
I added a custom CSS class under WordPress Menus for the mentioned menu item ".kaufen" and added this custom CSS to the Rife Pro custom CSS:
.kaufen {
color:
#da291c !important;
background-color: #da291c;
Color: did not change anything. (Also without !important)
I added the background-color to check if I am addressing the right css class. Background color change works fine.
Inspecting the menu item I see that the color of (all) menu items is set by:
.top-menu li a, .top-menu li span.title {
color: #002d72;
If I change this
color: #002d72;
I change the color of all menu links - which is not what I want. I only want to change the color of menu link that has css class "kaufen".
Thanks for so much details! That helps a lot.
In that case please try such custom CSS: If this will not help, please send me to live link to your website and I will check what is going on.
