I managed to replace the thumbnails in the WORKS section. But where do I replace the big pictured behind that so they appear in a lightbox when I click on them.
Hi Air, I'm sorry, maybe I'm missing something, but since the example pics (BRAUN watch etc.) were already in WORK, I just replaced the pictures in FEATURED IMAGE so I can see my own pic in the gallery on the website. But when uploading the images in the left side of this page (SELECT/UPLOAD IMAGES AND VIDEOS) they won't show up on the website at all when clicking on the featured image. Isn't there a step-by-step tutorial I can use so I don't do anything wrong? 😮
Maybe there is some caching issue, that you don't see your images. Could you share a link to your website, and tell in which work you have made changes?
Thanks for your private message. So, in the end, you want something different. You want a gallery that will open to the lightbox. Currently what you have is a list of works, so this if for a different purpose.
Do you mean the slider that shows up in the lightbox after opening?
If yes, you can manage this in Work Media section while editing the work https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-media/
Best
rocketboy
1. OK, so create Album and add there all your photos - https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-media/
2. Set up it in bricks mode - https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-options/
3. Instead of current post list shortcode widget, insert widget for Theme Gallery - https://rifetheme.com/apollo13-framework/docs/content-management/elementor-widgets/
4. There select album that you have created and adjust all other options.
thanks for the detailed instructions. It helped.. my gallery is online now. and it looks awesome! :-)
Best
