I used Rife Free and had my Featured Images automatically added to the "page title area" (below the header and above the content). Screenshot attached.
I tried now to create the same layout in Rife Pro. I added a Featured Image for the page but it does not appear on the page.
Can you please tell me where do I find the settings to add the Featured Image and page title under the header in Rife Pro?
I tried to add it under "page details" and adding a Featured Image. Screenshots from the page settings attached.
I also added a screenshot of the Rife Pro theme settings for Page Settings - Single Page - Title bar (Top / bottom padding = 200 px)
Could you show me a link to the page where featured image is set but it not appears?
I suppose it could be covered by the overlay. Check option in Title bar settings for "Overlay color", and set it to transparent or semi-transparent.
thanks for you quick reply.
Your solution worked! It was hidden by the overlay color.
Best
Max
Have a great day!
