Hi Guys - hope youre good
I have an odd issue and cant find why.
My logo show the words testlogo on hover. I cant find this entry anywhere in customizer - the logo file is not named this and I need the hover entry to match the media file text.
Please can you help thanks - I cant do a screenshot as the text goes away when I try to press ctrl!
https://metta3.com/thanks
This string is in your SVG file. If you edit it your logo file you will see
<title>testlogo</title>
.Remove it and you will be fine :-)
