I'd like to suggest an option to disable the lightbox, depending on device type. For me, I don't think it's useful on smartphones, where it actually takes up less area than the bricks.
I will think about it, but it seems a bit not worth the effort as lightbox script still will be downloaded and the user can view photos without opening them to a lightbox, and as you say just view the bricks ;-)
It is added in new update 2.3.8. In each album, you have option to disable lightbox for mobile, right under Open bricks to lightbox option.
