Hi Guys..Happy Tuesday and nearly Easter!
Im looking for some advice on editing the blog template. As its theme coded I cant use elementor pro..
What do you recommend?
I can rebuild a blog template only using Elementor Pro - but will reading>blog still call the WP template??
I really need the option to use Elementor Pro Blocks inside your blog template.
I hope to have something like this
https://kinsta.com/blog/ - see CTA in middle - not too hard
or perfect would be this with pinned post at the top
https://www.lyfemarketing.com/blog/Also
Related Posts for Blog Page - whats your recommended way to add these in the same category - plugin?? or hard code in template. If its code any chance you can share the code for display in same category only. I know that related posts plugin are a real drain on loading
See example here in screenshot from kinsta
Thanks & Happy upcoming Easter as well ;-) When you will recreate Blog page in Elementor Pro, you will have a normal page, that you can link in your menu. You don't have to worry about the page set in above mentioned setting.
So design it as you wish:-) I don't have any recommendation, but if you have found anything that is interesting, please let me know. I will check how it works, and we could style it or add better support for it in Rife.
