//RTL site? if(is_rtl){ scroller_options['rightToLeft'] = true; }
niv656 said: how can I prevent clicks on the images?
niv656 said: And turn off the green button?
niv656 said: I could not
Thanks for this report. Indeed there is a bug there in RTL version. I will fix it for next update, as it need to be corrected in JavaScript files.
1. Go to js/script.min.js and remove everything.
2. Copy there contents of js/script.js
3. Look for code: and remove it.
4. Save.
Please see https://support.apollo13.eu/discussion/comment/23758/#Comment_23758
You wanted to make edits. What is the problem?
