Hello and by the way again, great theme. I upgraded my theme via ftp, but I noticed that my social icons have disappeared. Goto to Jimmyemanon.com and look in the top right-hand corner and on the bottom of the page. You will see the circles but no social icons.
its like this on all of the works pages. - http://jimmyemanon.com/work/hydeparknowdoorhanger/
and all of the button icons are missing also.
thanks again
It seems you have many plugins that adds font-awesome so that might be the reason for missing social icons, as they all overwrite each other and theme.
Try first updating all plugins, plus theme bundled plugins https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-bundle-plugins/
It seems you have added them with some plugin, and now this code returns empty images, like this
<img class="mpc-transition " src="" alt="blackchicagonow-doorhanger2" title="blackchicagonow-doorhanger2" width="" height="">
.Maybe it is caused by images being moved to Amazon and removed on your server?
For example, I don't see image http://jimmyemanon.com/wp-content/uploads/2017/08/20234830/blackchicagonow-doorhanger2.jpg - it returns 404 error.
However, copy on Amazon still exists http://s3.amazonaws.com/jimmyrucker/medev/jimmy3/wp-content/uploads/2017/08/20234830/blackchicagonow-doorhanger2.jpg
http://jimmyemanon.com/work/flat-ul-kit-6/?preview_id=10018&preview_nonce=daed81b58e&_thumbnail_id=10083&preview=true
the image is here http://s3.amazonaws.com/jimmyrucker/medev/jimmy3/wp-content/uploads/2017/08/21182732/bronzevilleflyer-1920x1440.jpg
but it still shows up broken on the page. I use the amzon aw3 on a few site with no problem. Could you take a look.
And also does the template work with the eliminator ? I have been thinking about changing some of my site over because of the price for unlimited sites.
It looks like issues on your page could be connected to few things:
1. SSL links(https) are not working correctly. There is either issue in WordPress configuration or you need to update links in various places.
2. Please update FatMoon to newest version https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-theme/
3. Please update WPBakery to version 5.7 https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-bundle-plugins/
You will need to deactivate WPBakery while updating it beacuse of bug in this plugin.
4. Please deactivate all plugin except for: WPBakery Page Builder and Apollo13 Framework Extensions.
We have to make your page work normal while no other plugin is interefering. Currently I see some plugin are making JavaScript errors. Eliminator? Never heard of such thing. Is it some plugin?
If you mean Elementor, then yes FatMoon is compatible with it BUT it has no demos ready for Elementor.
However, our RIfe Pro( https://apollo13themes.com/rife/ ) theme has all demos( https://apollo13themes.com/rife/designs/ ) dedicated for Elementor. Rife and FatMoon are built on the same framework, so they have the same features, but differ in available demos.
Wiht kind regards.
I have tried to load your page a few times, but it doesn't seem to work, so I can not view it.
Do you have some problems with your website currently?
