I did enable the parallax thing, thinking it was for the cover
I looked and looked and started to get all confused, because nothing has excerpt or "more tag" anywhere. Then, I don't know why, I did a "select all" in the excerpt field and voila, apparently lots of TAB are present there. All the blog posts that didn't show any excerpt are imported posts from my older site. Must have been some trash during export/import.
You have enabled image parallax for this post, that is why it has reduced height.
Please see option Featured Image : Parallax https://rifetheme.com/help/docs/content-management/posts/posts-options/ You probably have used "More tag" in those other posts. Please see http://rifetheme.com/help/docs/content-management/posts/posts-excerpts/
