Update problems
in FatMoon Posts: 5
I was doing some maintenance and updating today (to PHP ver 7.2 first, then updated theme through envato plugin), and while on first glance I thought everything went ok I am getting an "undefined constant" error now on page load, and my top bar is now on a white band instead of floating over the background image. I am sure that is just a setting somewhere, but I can't find it for anything.
http://www.lucidarc.com
Thanks.
    edited May 2019 Posts: 10,970
    It seems you had a very very old version of the theme ;-)
    Go to child theme files(wp-content/themes/fatmoon-child-theme/functions.php on line 14 and change A13FATMOON_THEME_VER to A13FRAMEWORK_THEME_VERSION.
    It will fix the issue.
    "It seems you had a very very old version of the theme ;-)"
    I like the "if it's not broke, don't fix it" strategy!!
    Changed the line and its all set.
    Thank you!
    As far as I agree, security is not something that you will see that is broken, but it will hit you hard.
    That is why it is worth to be up to date - updating once a month seems reasonable ;-)
