FatMoon Missing Pages Theme Bug
edited June 2019 in FatMoon Posts: 5
Hello
Currently, I'm missing some pages throughout my site.They're showing up as VC designed pages, using in the admin but not showing up on the frontend. I copied the page templates and tried recreating the page but it's till not working out for me. I talked to my host and he says the server is fine.
I forgot to mention that the site has been running smooth for a long time until this issue and I always update my sites through the Envato WP plugin.
Also, I'm using the FATMOON theme and the url is https://www.cdgadvantage.com/
Thanks for your time!
Post edited by Melmcc on
    Hi Melmcc,
    We have released the update about an hour ago on the ThemeForest,
    please update the theme and let us know if this helps.
    Best regards,
    Lead Graphic Designer
    Thank you!
    I updated the theme as well as the Apollo plugin and the pages are visible again but the Apollo custom elements on those pages aren't working.
    For example, the page https://www.cdgadvantage.com/careers/
    should have a VC banner with animation that says' YOU BELONG HERE"
    Another example is on https://www.cdgadvantage.com/about-us/
    This page is missing the VC animated banner and should say "CDG ADVANTAGE"
    Thank you for getting back to me so quick!
    I'm having the same issue as Melmcc. Since updating to Fatmoon 2.4.1 and WP Bakery 6.0.3, the "writing effect" in WP Bakery is no longer function and won't display the text at all for that element.
    Looking at the rendered code, it appears it's setting the sentence to be typed as the "background-color" for some reason. See image.
    365 x 234 - 21K
    Thanks for the info. We have released second update 2.4.2 today, that has a fix for that.
    Sorry for the problems.
    Working again. Thanks for the fix.
    Thanks for the updates! Everything is working perfect now :)
