Hi Dan and Air!
Luckily a customer got in touch via text to complain I hadn't replied to her emails, which I didn't get. I tested both my sites and my contact forms are no longer working.
Please could you advise how to troubleshoot and fix? It's pretty urgent, no idea how much business I've lost because of this...
Kind regards,
Heather
On your place, I would contact server admin about this, so their could check if e-mail is configured as it should.
You can also try to contact your "contact plugin" support.
Which page is it by the way?
Want to thank me with coffee?
Very hard to tell when it could happen? Are you using WinForms Lite for a contact form?
It would be good to search if other users of your contact form plugin had experienced a similar issue, as it is a disturbing situation.
