Hi there,
Just want to report that the writing effect is not working when placed at the last row or bottom of the page; The blinking cursor did not appear either - I need to open Inspector to trigger it to work.
Any tips or tricks to make it work at the last row, i.e. timer or something?
Could you show me a live example of such a situation?
I will also try to recreate such a situation.
I think it is fired only when it reaches the middle of the screen.
It should work better with the next update.
Thanks for pointing this out.
