Great Themes with Elementor!
I'm using Brownie Rife Pro Theme. Trying to change upper and lower footer height.
• I like the default "About Me" area at bottom for this theme, like to change the color on "About Me" to 0099FF (blue) instead of black,
• also the whitespace above as it is really high on top. Need to tighten spacing.
• Trying to change the solid footer to a 2 color OrangeMagenta gradient.
Finally, how did you create the info sidebar reveal for Apollo13? is that widget inside sidebar theme options?
Much thanks for any suggestions.
Thanks for comming to the forum! You can find options from this flyout box in Appearance → Customize → General settings → Flyout box https://rifetheme.com/help/docs/customizing-the-theme/general-settings/flyout-box/
Go to page options( https://rifetheme.com/help/docs/content-management/pages/pages-options/ ) of this page, and turn off "bottom padding" : Page detials → Layout & Sidebar → Content : Top/bottom padding
Please use such custom CSS: Make your gradient here https://cssgradient.io/ and later copy generated CSS into such selector and add as custom CSS: Hope that helps.
