Hello, everybody,
I'm new here and from Germany. I hope that I can explain my problem to you correctly.
Currently I have Rife ProVersion: 2.4.1 running in the current Wordpress version.
I installed the OneLander theme including the demo data. A really nice theme, but unfortunately I have a problem with the main menu.
I use Elementor for different pages and as soon as I add something to a page, the main menu doesn't work anymore.
I've set the icons to be displayed during mouse-over, but it works, too, but only above the menu item and not as a single icon. In my albums or works it is quite normal to create a new page without using Elementor as well.
What am I doing wrong? :-/
A picture with the comparison:
Thank you so much for your help!
Best regards
Could you show me a link to a page where this issue happens? I suspect there is broken HTML somewhere, and that is why you see this quirk.
Link 1
New page without Elementor content:
Link 1 - NEW
Link 2
With elementor content:
Link 2 - with content
And what also doesn't work properly is that the main menu pushes up. You can see the difference very well here: Example in a album
The menu always has the same height when you scroll. This is not the case with the page (link 2). There it moves up. :-/
There is such CSS file added when you use Elementor : https://www.blickfrisch-design.de/wp-content/plugins/ultimate-addons-for-elementor/css/uae_custom_styles.min.css
and it adds such nasty CSS This is why the header is broken in many places.
Filename suggests it is custom CSS - have you added it?
Yes I did, but my own CSS is only about WP form and the tip from the forum here, because of the button in the albums to navigate to the next page.
That is the whole own CSS which is indicated in the Customizer:
.wpforms-form button[type=submit] {
background-color: #595959 !important;
color: #fff !important
} .wpforms-form button[type=submit]:hover {
background-color: #eee !important;
color: #008fd6 !important
.scroll-below {
display: none;
File path suggests this CSS comes from "ultimate addons for elementor" plugin.
I don't know this plugin, so I ask does it have some custom CSS filed, or some special options that adds this CSS? You don't have to know the answer, but maybe you have a clue:-)
Disabling this plugin should help.
Plugins shouldn't add such global CSS rules, as it will affect every theme and plugin in some way.
PS. I am off for today, see ya tomorrow!
I have not installed this plugin anymore. Can I delete it somewhere, if so in which file?
Many thanks for your help so far! :-)
I'm all right now! :-)
It was another plugin, but it also belongs to Elementor.
I meant, if I can delete the added CSS somewhere. I know how to remove plugins. :-)
