When I create a portfolio (works) as an overview and select that all filters/categories should be visible, it doesn't show all of them. But there are several filters/categories:
I don't think I understand what you mean :-) Filters only work for queried items. So if you query for 9 works, only them can be filtered.
If you don't want to show more then 9 works at start, then please change default category to something else then "All"(that has 9 or fewer items in it), but set query for more works.
Does those categories that are not displayed, some "Works" attached to them? Empty categories are not displayed.
If yes, then go to such find a "work" of the category that is not displayed, edit it, and save. It should refresh the database in that matter.
Yes all are available and I have already edited and saved a work. Still doesn't work. :-(
Categories are not displayed, because you have a limited number of Works to 9, so it shows only categories of those 9 works that are displayed.
If you increase this number in the widget you will see more :-)
Oh man... great, how easy :-D
Thanks a lot!
I want to show max. 9 works, but all categories. Isn't that possible?
Ok, then I have to think of something.
Thank you very much!
