Filters are not displayed
in Rife Posts: 36
Hi there,
the german has a problem again. ;-)
When I create a portfolio (works) as an overview and select that all filters/categories should be visible, it doesn't show all of them. But there are several filters/categories:
Unbenannt-1
    Does those categories that are not displayed, some "Works" attached to them? Empty categories are not displayed.
    If yes, then go to such find a "work" of the category that is not displayed, edit it, and save. It should refresh the database in that matter.
    Hi :)
    Yes all are available and I have already edited and saved a work. Still doesn't work. :-(
    Thanks for the data.
    Categories are not displayed, because you have a limited number of Works to 9, so it shows only categories of those 9 works that are displayed.
    If you increase this number in the widget you will see more :-)
    Really? Damn it... haha.
    Oh man... great, how easy :-D
    Thanks a lot! :)
  • edited June 2019 Posts: 36
    But if I increase the categories from 9, several examples will also be displayed. That's not supposed to be.
    I want to show max. 9 works, but all categories. Isn't that possible?
    Post edited by mindkicks on
    I don't think I understand what you mean :-)
    Filters only work for queried items. So if you query for 9 works, only them can be filtered.
    If you don't want to show more then 9 works at start, then please change default category to something else then "All"(that has 9 or fewer items in it), but set query for more works.
    Yes, you already understood correctly :)
    Ok, then I have to think of something.
    Thank you very much!
