Optional top bar colors
in Rife Posts: 52
The optional top bar is black on my frontpage, but looks correct on other pages, where the main menu is different. I can't use it as it is now.
http://v2.zafariqbal.dk/
    You are probably using some(light or dark) header color variant on your frontpage. You can adjust colors of the top bar in used variant options in the customizer.
    Please read more here https://rifetheme.com/help/docs/customizing-the-theme/header/variant-light-dark-overwrites/
  • Thanks, that helped! :)
    But now I have a new challenge. Even with social media icons disabled, the full width isn't used for the text part - only half or less, which on a phone is very little, even for a short sentence.
    It should work fine.
    Could you send me a link to live example? On the site from the first post, I don't see top-bar or the header.
  • I've looked using Chrome on mobile, and it looks like in the screenshot.
    Just tried Chrome on Desktop and here too, it looks wrong, no matter what browser size. With Firefox on both Desktop and Mobile, it looks as expected, but very few visitors use Firefox.
    I've tried clearing all cache and minimized CSS and I also tried removing all custom CSS. It didn't make any difference.
    1080 x 2160 - 894K
    But what is the link so I could check it as well?
  • I had removed it, which is why I showed the screenshot - but I just enabled it again:
    https://www.zafariqbal.dk/
    edited July 2019 Posts: 10,970
    OK, it looks good in FireFox but not in the Chrome.
    Please add such custom CSS:
    .top-bar .part1 {
        width: 100%;
  • That did the trick. Thanks!
