Hi Air,
I am in the process of populating the "People" section on OneLander 2.4.3, and would like to have your assistance with a custom CSS that performs the following:
1) Reduce the font size for the Name (title) part of each "People" box.
2) Expand the size of the field that holds the name.
3) I do not want the name to be truncated.
I have some long names, and they are rolling to the next line and I would like to see if I can avoid that. I would very much appreciate your assistance with this CSS!
Please share a link to the website when I can see the live code and result, so I could assist you precisely.
Thanks for the link via private message.
Here is the custom CSS: If this still happens, could you show me this on the screenshot?
All of this worked to satisfaction.
This is the reason why I rated you guys 5 stars!
I would certainly consider this template again for other clients... It is attractive and has a logical layout that is easy to work with.
Great job!
Thank you so much for your kind comment. Make my evening ;-)
Wish you all the best!
