dear apollo team since the last updates, i'm not able to add pictures to my albums. the menu for adding pictures is missing. if i install an older version of the theme form autum 2018, than menu appears. thanks for help Claus
I maybe found the "failure". there where 2 apollo frameworks installed in 2 different versions. maybe it was installed during updating the theme? but its right to have installed only 1 framework (version 1.7.x) thanks
It seems like you didn't update the theme for a long time :-)
Just keep the newer version of Apollo13 Framework Extensions, as meanwhile it was added to WordPress plugin repository instead of being bundled with the theme.
thanks
Yes, this is the true reason.
