i've an issue on my web site using onelander theme. In backend home i get this error:
Fatal error: Uncaught Error: Call to undefined function Apollo13_FE\a13fe_theme_scripts() in /home/concre/public_html/wp-content/plugins/apollo13-framework-extensions/supports/elementor_extensions/widgets.php:55 Stack trace:
#0 /home/concre/public_html/wp-includes/class-wp-hook.php(286): Apollo13_FE\Widgets->widget_scripts('')
#1 /home/concre/public_html/wp-includes/class-wp-hook.php(310): WP_Hook->apply_filters('', Array)
#2 /home/concre/public_html/wp-includes/plugin.php(465): WP_Hook->do_action(Array)
#3 /home/concre/public_html/wp-content/plugins/elementor/includes/frontend.php(404): do_action('elementor/front...')
#4 /home/concre/public_html/wp-content/plugins/dashboard-welcome-for-elementor/classes/class-dwe-admin.php(224): Elementor\Frontend->register_scripts()
#5 /home/concre/public_html/wp-content/plugins/dashboard-welcome-for-elementor/includes/welcome-panel.php(6): DWE_Plugin\Admin->render_template()
#6 /home/concre/public_html/wp-content/plugins/dashboard-welcome-for-elementor/classes/class-dwe-admin.php(125): in /home/concre/public_html/wp-content/plugins/apollo13-framework-extensions/supports/elementor_extensions/widgets.php on line 55
I added an screenshot.
If I disable Apollo13 Framework Extensions the error disappear but i still have a problem to edit any page with a elementor preloader spin in an infinite loop without loading the editor.
Can u resolve this issue please?
thanks
Daniele
It looks like "dashboard-welcome-for-elementor" plugin could get in conflict with something in our theme or plugin. Could you try to switch it off and check will it work then?
