Lightbox without Decription
in Rife Posts: 36
Hello, everybody,
does anyone know how to turn off the description/title etc. below the lightbox? There should be nothing underneath.
Many thanks and best regards from Germany!
    If this is lightbox in bricks album then you can disable it in Album. Go edit Album → Album details → Album media → Show title and description of album items..
  • No, it's integrated as a theme gallery. This function does not exist there. Sorry the picture is in German, hope you understand it anyway.
    335 x 574 - 31K
    Still, if Gallery is made from the album, you should be able to disable it in Album, even if in widgets there are no controls for it.
    Please try it.
  • Yes, I know :) but it is deactivated...
    779 x 255 - 30K
    OK. I will check on my installation and reply later.
  • Thanks a lot!
    edited August 2019 Posts: 10,970
    I have checked, and indeed Gallery widgets don't respect setting for description texts. I will try to fix it in the update of Apollo13 Framework Extensions plugin that should be released tomorrow.
  • This sounds great, thank you! :)
