Greetings,
so I am using Rife Pro on multiple client sites, i got messages from these clients that apperently their sites are marked as "not safe" in browsers. So i looked into it and after a lot of digging and almost nothing working i decieded to copy a whole client wordpress instance into an isolated webhosting and check if i can get rid of the safety problem by deleting parts of the site and deactivating plugins.
Sure enough after this process, it turned out that the "Apollo13 Framework-Erweiterungen"(German for Extensions) Plugin is causing this issue somehow.
That became even more clear when i activated all other plugins, and the issue was not present. But after activating said plugin - it was there right away.
Would be great if you could look into this and take care of it.
Kinda dissapointed that an (probabaly) update with this effect is even send out.
Sincerly,
Sabera
As I understand you mean that some content, like images, are served by http instead of https, right?
Please show me live link to such site.
If I am correct you just have to refresh generated user.css file, so it contains proper links to images. Try doing this by going to customizer(with active plugin), changing something, and saving changes.
This happens when you switch the site from HTTP to https after the site is already live:-)
Unfortunatly nothing worked.
In case of this website those files are served by http instead of https:
„http://fixautoverkaufen.de/wp-content/uploads/2019/08/Fixautoverkaufen.jpg” „http://fixautoverkaufen.de/wp-content/uploads/2019/08/logo.png” „https://fixautoverkaufen.de/wp-content/uploads/2019/08/Fixautoverkaufen.jpg” „http://fixautoverkaufen.de/wp-content/uploads/2019/08/ErklaerungsvideoGlanzAutomobile.mp4” „https://fixautoverkaufen.de/wp-content/uploads/2019/08/logo.png”
So for sure please go to the logo section and try to select image for logo settings once again.
I see that in your HTML some images are also served by http, so I suspect that not all settings in WordPress are set correctly.
Just to calm you - plugin is not the issue, but the wrong links to few files are, and it seems that they are either cached, like in user.css file, or glitched due to other settings.
I can take a look at this website tomorrow.
If you like me to do it please send me temporary* access to your WordPress and so I could check there what is going on. Send it here on the forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
So deactivating plugin didn't solve the issue - various files were still served by HTTP. Not sure what you have seen while deactivating the plugin, but it didn't solve anything for me.
As for logo - I have reset logo image in all places- in all header color variants and in normal logo settings, as it seemed that there were stuck some old settings, even that they didn't appear in the customizer.
Last 2 files that you have to fix in your content in the Elementor are:
-'http://fixautoverkaufen.de/wp-content/uploads/2019/08/ErklaerungsvideoGlanzAutomobile.mp4'.
'http://fixautoverkaufen.de/wp-content/uploads/2019/08/Fixautoverkaufen.jpg '
After these links are fixed, you shouldn't see any SSL warnings anymore.
Hope, now all will go smooth for you :-)
About fixing the last two files - deleting them and reuploading them over wordpress should be sufficent right?
Thanks for ur help.
