A weird error
Thumb for the latest album isn't showing correctly: https://www.zafariqbal.dk/bryllupsbilleder/
I don't know if it's theme related and it seems, it only happens when Autoptimize is enabled.
I've tried the following, while Autoptimize was enabled:
- Duplicating the album (using a plugin) doesn't fix the error.
- Creating a completely new album, with the same images, doesn't fix the error
- Changing to a different featured image didn't fix the error
- Changing the status to draft, so a different album shows up as #1, works fine.
If I disable Autoptimize, it looks correct. But it's because of the last point, that I'm not sure if it's theme or Autoptimize related.
I've used Autoptimize for a while and have checked the album list many times. This is the first time I'm seeing such error.
