Discussions
Categories
Home
PhotoProof
Reader logo has disappeared
AndreLIma
October 2019
in
PhotoProof
Hello, the header no longer shows the logo in the totally dark version (as in image 02). When I use the scroller menu, it appears normally (as in image 01). Where am i going wrong? Thanks.
Air
October 2019
The logo is there, but it is totally black. So black on black - you know how it looks ;-)
As you are using there normal header color variant, you will have to switch your logo image in
Appearance → Customize → Header Settings → Logo
Please also check the info about header color variants
https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/header/variant-light-dark-overwrites/
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
590
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
October 2019
Air
Discussions
Categories
Sign In
As you are using there normal header color variant, you will have to switch your logo image in Appearance → Customize → Header Settings → Logo
Please also check the info about header color variants https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/header/variant-light-dark-overwrites/
