Customize Form Template
How can I customize the theme template's form, specifically the button and the font? I want it to use Open Sans and have the button look like the attached. (arrow not required, mostly just the black outline)
    Hello Laura:-)
    Could you link to a page where this button appears so we could help you with that?
    Please go to button settings and set most thing there Appearance → Customize → General settings → Buttons.
    Font for buttons is the same font that is used for titles. You change this in Appearance → Customize → General settings → Fonts settings
    With missing parts, I will help you by custom CSS, but you should do it all(without the arrow).
  • Thanks that helped but I'd love for to look like the rest of the arrows. Could you help with the custom CSS? Thank you :)
    Hey Laura :-)
    I can not recreate the arrow in button with custom CSS.
    What other details are you missing to achieve what you need?
    As for background color, please remember that you can always set the transparent color by reducing the opacity slider to 0.
