How do you update the mobile version text inside of my hero image?
How do you update the mobile version text inside of my hero image? It looks like there is a lot of padding. Is there a way to get rid of the padding on the mobile version but keep it like it currently is on the desktop (see screenshots of both).
Website URL is: http://behumaneleather.com/what-we-believe/
    Hi there,
    You must edit this second column where you have your text.
    Go to the column settings and Responsive options (check my screenshot).
    I hope it helps.
    1461 x 820 - 126K
    Lead Graphic Designer
  • Thank you :)
