I used the theme importer to update a website to photoproof theme 6. I updated the menu to link to my existing albums but the mouse-over drop down effect from the demo doesn't seem to work anymore. I'm not sure if I turned it off or I removed something I shouldn't have.
If you could post a link to your website, then I could check what is going on.
Anyway please check if Submenu icons are enabled and set in Appearance → Customize → Header Settings → Main Menu → Submenu/mega menu open icons.
