I am getting an endless loop a message saying I need to update my WordPress database (Screenshot 1); when I click it, it says I am already up to date (screenshot 2).
I double-checked and I am on the most recent version of WordPress. I read somewhere that it is a caching issue but I can't even get to the plugin page to turn off any plugins that might b causing the issue because this message pops up immediately... Please help!
Please login to your FTP and go to wp-content/plugins and rename each plugin folder that you want to disable to something different. For example 'cacheplugin' to '_cacheplugin'.
This will disable such plugin until you will rename it again to the orginal name.
Do you have any other plugin recommendations similar to autoptimize that can help with site speed? Our site is extremely slow even after optimizing image sizes, file types, etc.
Thanks.
One site, it worked great for about 2 days then crashed all pictures on the site. The other site never ended up working. Clearing the cache worked about 30% of the time. I spent days trying to identify which feature was causing the issue and never reached a conclusion. Very sad as I have not found another plugin that has the same amount of options!
Sorry but I don't have any alternative for you that I could recommend.
I can recommend asking on the general WordPress support forums.
